You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
At what percent biodiesel are you using on a regular basis? There has been a lot of discussion on this and thought we should get a feel for what was the most popular
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
Locally I can't get bio, as it is dyed fuel.... otherwise, i'd be running it.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
I just found out from my fuel supplier that the price difference between the B5 and B20 is $ .05
__________________
B5 soydiesel user
Sirius radio
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
__________________
Administrator
I get Soy Diesel from Agriland FS that is 10% and love it. In Western Iowa, the Co-Op and FS stations have Soy Diesel, but it varies from 2% - 15% depending on the station. Here it is 1 cent per percent soy cheaper than regular diesel.
Total Loss - '03 F250 SD Toredor Red over Arizona Beige - Crewcab, Short box, 4x4, 6 Liter Power Stroke, 5 - speed Torqueshift, SPA dual gauge (Boost over Pyrometer), Predator, B&W flip-over ball
B10 now and no problems. Will go to B20 soon
__________________
05 F-250 CC SRW LB 4x4 6.0 Tow Command Lariat Remote Start All Stock 01 Alfa 40' Toyhouse for all the toys.
I'm doing my part to reduce our dependency on foreign oil and clean up the environment; my truck runs on 100% biodiesel made from soybean oil grown by U.S. farmers. What are you doing?
I will leave it here until Monday and then move it to the 7.3 forum, that way we should get a good sampling.
__________________
Administrator
I'm a big fan of Bio-Diesel and wish that we as a country could role it out on a large scale. It would be good to have all the OTR trucks running BioDiesel. I don't believe its available (Washington DC) in my area, if it were I would run it!
Ford doesn't recomend Bio-Diesel to protect themselves from the unregulated "Home Brew" fuels. Ford also doesn't build the diesel engines they use either.
The Soy Diesel you buy at the pump is safe to use in your diesel. It has to meet the same minimum standard as any other fuel being sold. Soy-Diesel is better for the environment because it uses the Soybean oil to replace the sulfer as a lubricant. Soy-Diesel will also help clean any your tank (this is what can plug your filter the first time you use it. Not the Fuel, but the dirt that was in your tank already.) Our FS runs there fuel tanker on 100% Soy Diesel with no problems.
Ikold, go to www.biodiesel.org for fueling locations in the DC area. I looked and found 6 in Maryland and 12 in Virginia. 3 in De. Hope this helps.
__________________
B5 soydiesel user
Sirius radio
fords stand is: Up to 5% soy biodiesel is OK. Check TSB's at top of screen.
__________________
B5 soydiesel user
Sirius radio
