Catalytic Converter failure?
Old 06-26-2005, 05:51 PM
llee's Avatar
llee
llee is offline
Question Catalytic Converter failure?
92 explorer 4.0 4wd 220,000 mi
This past Tuesday I finished replacing the lifters(new lifters, rocker arms, pushrods, valve stem seals, etc) & on my truck. In the process of putting it back together I cut one of the orings for a fuel injector. It ran ok for a day or so bt then the pressure caused it to fail. It started spraying gas everywhere(several gallons worth in maybe a minute or so).
After replacing all the orings on the fuel injectors the truck ran great. Friday on my way home I went from crusing at 45 to 25 very quickly. the check engine light came on at the same time.
I stoped and opened the hood. The engine sounded normal. As I walked along the passanger side it sounded like there was a potato(e) in the exhaust.
I limped home the last few miles.
Saturday I was turning the truck around to take a look at it properly. Everything was fine. Ran up and down the street a few miles with no problems. So I got braver. Made it about 5 minutes before the same thing happened again.
I am thinking that after 13 years and 220k miles the converter has given up the ghost. Once it gets hot it clogs up (possibly also caused from a lot of fuel dumping into the engine from the failed oring?)
Before I just go and buy a new converter & exhaust system(a cat back sytem was my much needed next project for this anyway) I wanted to check and see if it is the converter. (I have never had one go bed beforeso I dont really know the symtoms)
Thanks
Les
Old 06-26-2005, 06:58 PM
don96exp's Avatar
don96exp
don96exp is offline
I had a bad convertoer on one of my cars and it would'nt go faster than 40mph. With 220k miles that's not bad.
Old 06-27-2005, 09:16 AM
FloatJ's Avatar
FloatJ
FloatJ is offline
I had one go bad on a previous car as well. The symptoms sound exactly the same. Good luck.
Old 06-27-2005, 05:50 PM
Jharger's Avatar
Jharger
Jharger is offline
Check your code first. The PCM wants to tell you something.
A bad cat can do what you describe. The honeycombs on the inside physically break into chunks and when they turn sideways, gases don't go through them to well. My old VW Jetta did this and it bucked like a bronco for about 20 seconds, slowed down to a crawl, I put it in nuetral and blew out the motor, then it was fine. Good thing too as I was in the middle of a 3 mi long bridge with no emergency parking lane.
But there are other things that can do this, conceivably a MAF meter, IAC valve, bad coil - who knows? Go to this web page for a list of codes. If it is the cat, a O2 code might occur since you sensor is just upstream of the cat.
http://fordfuelinjection.com/?p=1
The Hooligan
1997-2006 Expedition & Navigator
11-29-2016 01:33 PM
JHG88F350
09-05-2016 10:50 AM
Adam Callan
01-31-2016 04:40 PM
Skyhawk Greg
73
09-15-2014 10:29 AM
jeffreyt
10-18-2012 07:16 PM
Quick Reply: Catalytic Converter failure?
