For Those Who Brew Their Own...
Well, having seen how the biodiesel scene is beginning to take off and the ridiculous prices for overseas diesel, I've decided I want to buy a kit and turn the WVO to biodiesel...I really like the Freedom Fuel America Kit ( www.freedomfuelamerica.com ) ..However, I think that $3k is a little out of my price range for a kit..Does anyone have any other kits that they know of that are similar but are lower in price? Or does anyone have any experience with these make-it-yourself kits? Thanks
It's alot easier to just use WVO. I think bio is alot more complicated and isn't worth the time. But, you be the judge. Here are some sites.
http://www.greasel.com/index.html
http://www.greasecar.com/forum.cfm
http://biodiesel.infopop.cc/eve/ubb.x
http://www.frybrid.com/forum/
http://www.greasemachine.com/forum/
http://www.localb100.com/cbt/mainpage/
That's probubly enough reading for the next 2 weeks.
Let us know what ya think!
This is the one I like: http://www.biodieselwarehouse.com/
It involves alot more DIY, but is way less expensive.
OK guys I am using a pump and a two filter system. First filter is a regular PH8A or equal. Second filter is a large can fuel filter Car Quest 86281. I settle my oil to remove the solids and pump it through the two filters into a 5 gallon plastic can. I then allow it to settel again for a day or two and then pump again through the two filters and into the truck tank. I run about a 25% mix and have been told that I can go as high as 50% with no other modifications to the truck. My mpg has gone up slightly 1 > 1.5 mpg. My fuel bill has droped by $26.00 per fill or $2.60 per gallon. The price of #2 here.
Questions: Am I missing somthing in the processing that I should be doing? My oil is free and comes from a resterant that does mainly home fries in this oil. I do not get greedy and am very carfull about keeping things clean. The filterd oil is clear and dark amber in the 5 gallon jug. I am in southern CA so the temp is not a poblem. The high pressure pump has gotten a lot quieter on this 01 7.3 Ford. The resteraunt owner shure likes the free oil removal, they were paying about $1.50 a gallon to the black gold people every week for 15 to 30 gallons.
Joe
JOE-M, You only use lye if your making BIO-DIESEL, totally different ball game. And yes you should heat it, that's to get any water out, if you know the source of the oil and that it doesn't have water or you tested for none, then that process can be skipped.
Maybe this should be moved to the ALTERNATIVE FUELS forum...
For those with more questions read this first post: http://biodiesel.infopop.cc/eve/ubb....51&f=159605551
Originally Posted by MasterTrim
...JOE-M, You only use lye if your making BIO-DIESEL, totally different ball game. And yes you should heat it, that's to get any water out, if you know the source of the oil and that it doesn't have water or you tested for none, then that process can be skipped.
Joe
The micron size is 1 or less.The clarity is clear, and no water cause the second filter is a water trap and fuel filter. In my case the oil comes to me warm with no water right out of the frier. Letting the oil settel causes the potato and some chicken fat to go to the bottom. From the last 15 gallon batch I got 12 of usable fuel and about 2.5 of desolved spuds. Looks like real fine cream of wheat cereal, and since I didn't run that through the filters they don't clog as fast. Olso what's left over can go right down the drain or in the garbage. It isn't a hazardes material, you could actually eat it. I have been looking for some kind of ceramic filter that I could use that would guarentee .5 micron and no watter. I would feel real safe then.
Sombody mentioned Lye mixed in the oil. For what purpose?
Cost of the filters and the pump and the tubing about $30.00. This = cheap fuel.
Wait till the people in the government find out we arn't paying road tax either.
Tooo bad.
Tooo bad.
