torque converter shutter?
Old 06-13-2005, 10:05 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
Originally Posted by dcrewchief
I thought i would post back and say that i did stop at the tranny shop today and they had some (Dr Tranny's Instant Shudder Fix) and has seemed to cure the problem. when they say instant they werent joking lol. So far so good thanks for the help folks.
glad we all could help.
if it was my truck i still would change fluid, filter, drain convertor. also add instant shudder fixx to new fluid.
just my opinion.
good luck!
Old 02-08-2006, 09:10 PM
87f150xlt's Avatar
87f150xlt
87f150xlt is offline
I think I have the same problem, I hope it's not too late as this problem has been going on for a few months. still curious as to find out what kind of transmission fluid must be used. 92 6cyl A/T with O/D
Old 02-08-2006, 10:08 PM
quicklook2's Avatar
quicklook2
a good quality mercon.
Old 02-08-2006, 10:10 PM
87f150xlt's Avatar
87f150xlt
mercon V? or III?
Old 02-09-2006, 10:22 AM
gatesj's Avatar
gatesj
gatesj is offline
87f150xlt, if you have the 6 cylinder and an automatic overdrive transmission then you have the E4OD that year. They did have some nasty issues with torque converter clutches, in fact that is what killed a lot of those transmissions.
Do not use Mercon V in an E4OD of that time period. Mercon only. Sometimes it comes as "Dextron III Mercon", it is a dual rating for boxes that take Dextron III AND boxes that take Mercon. There is no Mercon III.
Old 02-09-2006, 10:25 AM
quicklook2's Avatar
quicklook2
MERCON.
NOT MERCON V.
look in your owners manual.
Old 02-09-2006, 10:28 AM
87f150xlt's Avatar
87f150xlt
Thanks, maybe it's too late. but I'll give it a shot sometime.
Old 02-09-2006, 10:32 AM
quicklook2's Avatar
quicklook2
make sure you drain convertor, new filter and fluid and do not tighten the bolts too tight.
i recommend lucas trans treatment also. warm it in hot water so it flows easier and put it in after a gallon or so of mercon is in trans.
also, a product named 'shudder fixx' is a good thing. do a google search on it for where to buy it in your area.
Old 02-09-2006, 05:10 PM
MustangGT221's Avatar
MustangGT221
MustangGT221 is offline
Moved to appropriate forum.
Old 02-15-2006, 11:36 PM
babbler's Avatar
babbler
babbler is offline
i just got done having my tranny flushed and filter changed and had lubegaurd added and the shuttering is still there can a guy still try dr.tranny istant shutter fix? thanks
Old 02-16-2006, 12:57 PM
quicklook2's Avatar
quicklook2
did they drain torque convertor?
what do you mean by flushed? drained?
Old 02-16-2006, 03:41 PM
coppertales's Avatar
coppertales
coppertales is offline
I have a '96, 302 auto....
that had almost the same thing around 65-70k miles. A fluid change corrected the problem. It also had a stutter when upshifting from 3-4. I had replaced the air cleaner with a K&D and when I changed it back to stock paper, the stutter went away.......must have affected the vaccuum somehow......chris3
  #28
Old 02-16-2006, 10:36 PM
babbler's Avatar
babbler
babbler is offline
he flushed the tranny and and pulled the pan and put in a new filter and refilled it.is there a different way to drain the converter? thanks
  #29
Old 02-17-2006, 10:07 AM
quicklook2's Avatar
quicklook2
to drain convertor you need to pull a rubber plug below convertor remove the inspection plate to rotate convetor. align drain hole/bolt to hole and drain.
do this and remove pan and put in another filter and use shudder fix and lucas trans. treatment and new fluid and you may get rid of shudder.
  #30
Old 03-22-2006, 10:42 AM
Manual's Avatar
Manual
Manual is offline
Why would you use both treatments. does Lucas have a shudder fix additive in it. and what do you think of lucas products
Quick Reply: torque converter shutter?
