alt/ voltage regulator problem -help!
I just finished putting my 84 bronco together and I have a very large battery drain. I suspect the voltage regulator is bad because I have 12 volts to the BAT terminal on the back of the alternator and 12 volts to the field terminal on the back of the alternator with the key off. shouldn't the field terminal on the back of the alternator be dead with the key off ???? I can't remember but that makes sense. Also I thought my electric choke plugged on the field terminal on the back of the alternator also and I am sure that it should only be on with key. this is an external regulator. Your help is greatly appriciated. mike bryan.
1980302windsor
32
06-28-2022 07:39 PM
preferred88
05-16-2016 09:46 AM
saauvenshine
04-01-2016 01:50 PM
ktz78
12-20-2010 11:10 PM
