OIL & COOLENT specs.?
Old 05-26-2005, 10:10 PM
chipmunck's Avatar
chipmunck
chipmunck is offline
I need to know how many quarts of oil do I put in my 292-y and how much coolent/water?
Thanks
Pat
Old 05-27-2005, 01:10 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
well i think engine oil is 5 quarts and coolant you need 2 gals of concentrate coolant then fill the rest with water and do not use i repeat do not use any sm rated oil in the 292 the sm rated oil is for the new non flat tappet cam engines the 292 need a lot of zinc to protect the cam i woul use a good quality wix napa brand oil filter and a good dual rated diesel oil ci-4/sl like rotella t 15w40,mystik or delo
