Rear end housing leak?
I've been cleaning and painting the rear portion of my truck. I've notice a small drop of oil on the floor and occasionally on the bottom of the housing. I assumed it was the gasket on the third member was planning on replacing it. Now after painting the rear housing, I noticed the oil wasn't coming from the third member and it wasn't coming from the inspection plug. It almost looks like it's on the welded seam of the housing just underneath the inspection plug? Is this a common problem? What's an easy way of fixing this without yanking the whole rear end out. Since there is no pressure, I was wondering if good ole JB Weld along the seam would work, it's getting painted anyways.
That not a good idea.. The weld needs to be clean for proper welding.. And there is a good chance that you could start a fire in there.. even worse .. it could explode on you.. Tearing it down is easy and you wont need to reshim it afterwords.. And its best to do the weld from inside and grind it smooth.. Id do it from inside than outside.. grind the inside smooth and be happy with a job well done..
