changing timing belt on 2.0L?
Old 11-17-2005, 10:21 PM
JD717's Avatar
JD717
JD717 is offline
I'm going to need to ask before I get into this, how hard is it really? I have the belt in the cab to do it right now, but want to know how complicated it is before I get into it.
Old 11-17-2005, 11:59 PM
TigerDan's Avatar
TigerDan
TigerDan is offline
It's actually one of the easier engines to change the belt on. Things are pretty easy to get to. Plan on a few hours to be safe.
Old 11-18-2005, 12:20 AM
JD717's Avatar
JD717
JD717 is offline
Ok, that should be pretty easy I think. thanks for the info. the manual was and still is kinda sketchy on this subject.
Old 11-18-2005, 12:32 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
Sounds like you have a Haynes manual. They like to skip or gloss over a lot of info.
Check this out:
https://www.ford-trucks.com/forums/s...d.php?t=107538
Click on "2.3 Timing belt" and it will open in Word. Good info there.
Old 11-18-2005, 05:40 PM
JD717's Avatar
JD717
JD717 is offline
From what I saw, I'll have to pull the water pump to remove one of the bolts to remove the cover on the timing belt, the rest of it looks pretty straightforward though.
Old 11-18-2005, 08:29 PM
TigerDan's Avatar
TigerDan
TigerDan is offline
No, you shouldn't have to remove the water pump. You only need to remove the outer timing cover, and to do that you might need to remove the water pump pully, but not the pump itself.
Old 11-18-2005, 09:25 PM
JD717's Avatar
JD717
JD717 is offline
the pump itself, has a particular fitting on the top of it, that obstructs my access to the screw to remove the belt cover, whcih is why I think it needs to be removed to access the bolt holding the cover on to remove it.
rickfar
Escape & Escape Hybrid
12-07-2014 04:10 PM
cabloom300
07-22-2014 08:42 PM
2002exPSD
01-09-2014 11:10 AM
DGM
05-17-2012 07:36 PM
b4hntn
1978 - 1996 Big Bronco
07-31-2009 09:49 AM
Quick Reply: changing timing belt on 2.0L?
