first like to say hello new here,
i got a 85 bronco and want to make it a mud bog truck .
would like to put 3/4 or 1 ton axles under it but not sure which one will work .
First of all, welcome and best of luck with the project. You will need to swap to a solid front unless you feel like hunting down a 3/4 ton Twin Traction Beam Dana 50 for the front. Dana 60 rear is most common. I have not personally done this mod but some here have. The spring perches on the axles are the primary concern when getting everything lined up. 3/4 and 1 ton F-series had leaf springs rather than the coils that the 1/2 ton and Bronco had so thats a consideration as well. Unfortunately the extent of my knowledge wains here. Others will most assuredly respond though.
I put the 50 in mine due to no 60s being available. I thought it was an easy swap. The rivits are a pain to grind and you have to be very careful lining up the new pivot brackets. With the stock 90 F250 parts I clear 35s with 4" clearance in the wheelwells.
