Speaker Upgrade
Speaker Upgrade
I have a 2003 SuperCrew that has the single CD/cassette. For now, I'd like to upgrade the speakers and see if I can make it sound better. I'm not looking to sink a bunch of money into the system, at least not now.
So I saw some Pioneer's that said "Ford Applications". I think they were 6x8's. Is that what I need is that size? Are they going to make much of a difference?
Next question is how do I get to the door speakers. I'm sure I could figure it out, but I thought it would be best to ask someone who's probably already done it.
Thanks in advance.
Thanks in advance.
Yes 5x7 or 6x8 will fit.
(from the FAQ post at the top of this forum)
Q: How do I remove my door panels?
A: It depends on the panel style, but most you just pop off the upper trim pieces on either side, and pop out the retainers. If you have power windows pull off the switch plate and disconnect the power leads and set the switches and plate aside. Pull the escutcheon plate around the inner latch handle which just snaps into place. There will be one screw under that latch handle escutcheon plate. Remove that screw. Not all door panels have two upper trim pieces so if yours only has one then remove it and that retainer under it. If you have all the retainers out then simply grasp the bottom of the panel and give it a tug upward. The door panel has a bunch of hooks on the back side and you are simply unhooking them from the panel. The panel should then lift off and you just disconnect the courtesy lamp from the socket if equipped. Reverse order for installation. Some older model panels didnt have the escutcheon plate around the inner latch handle and just have a small trim piece you remove, and then you remove the handle itself with an 8 mm socket tool. Also some have an additional screw just inside the area where you pulled off the switch plate. If you missed a screw you will know as that panel will not budge. Some models may also have a screw hidden behind the lens on the courtesy light. If the lens is removable you will be able to tell by the indention in it made for a small screw driver to pop it out. (Thanks to HomerWinzlow for that answer)
silar
20
03-03-2015 10:23 PM
Genesis
04-18-2010 02:33 PM
MikeK2004
04-09-2004 12:58 PM
