Oil change question
Oil change question
Got an odd question with my 98 F150 4x2: whats the accepted amount of oil consumption between regualr changes? I just changed mine after 4.5k miles (1500 continuous towing) and I only got a little over 4 quarts out of the engine. I still put 6 qts in but it has me a little concerned. It also did this last year when I changed the oil for the first time (6 qts in, 4 qts out, 2.5k miles)
Hmmm.
I generally notice no significant loss (maybe 1/4 quart) between changes and I do 4500-5000 mile changes.
How many miles on the engine?
If you are missing 1-2 quarts it is either:
a) leaking out
or
b) burning oil.
I'd degrease the engine and get it as clean as I could. Then, drive regularly and check the oil level every week. If you notice the level dropping, look close for a leak. If no leak, it's bound to be going out the tail pipe.
Towing will generally cause a little additional oil consumption, but losing 2 quarts in 4.5K miles does seem excessive.
What weight oil are you running?
a) leaking out
or
b) burning oil.
Originally Posted by BrianA
Hmmm.
a) leaking out
or
b) burning oil.
a) leaking out
or
b) burning oil.
First oil change was 5w-30 (up in New England) amd I did 10w-30 for here in Florida. Truck only has 53k miles
