Yes the noob has another question :D
None as long as there is enough power behind the spark to jump the gap and ignite the fuel and air mixture. Most electronic systems will jump a gap of .100" whereas a point system will usually only handle .050". The wider gaps require more power which also causes faster wear of the plug tip unless you run high dollar hardened tip plugs.
on
1 Post
Well I dont totally agree with that.....A stock spark is usually about 25 to 30,000 volts..and jumps a .032" to .038" gap....for stock use or mild performane.. An HEI system is around 40,000 volts and generally jumps a .045" gap...Hotter spark longer jump (longer flame) Better Cylinder burn...
A Hi Performance Igignition... 50 to 60,000 volts will Jump a .050 to .060" gap (a longer yet Flame) Hence better cold starting..better combustion...cleaner combustion.. Hence a better running motor... a little Hp to be made..but not really enough to count on.. Just a better running engine...And in HP motors with High CR..you dont have to worry about spark blow out..with the good HEI Ignition...
Russ
Russ
Russ
Russ
"Hotter spark longer jump (longer flame) Better Cylinder burn..."
This statment is unture. You only need enough spark to ignite the mixture, any more is wasted and the only reason the manufactures went with hot spark systems is to compensate of the leaner mixtures to meet EPA requirements. The leaner the mixture the harder it is to ignite, so hotter spark required. Get rid of EPA and we would still prbably be using point systems (cheaper).
Ratsmoker
12-02-2002 07:23 AM
busdriver1
12-05-2001 07:09 PM
manlikesford
01-11-2001 10:17 AM
