4 cylinder 2.5 with bad gas milage
Old 03-28-2005, 09:40 AM
dbarracuda's Avatar
dbarracuda
dbarracuda is offline
Hey guys i have a 99 ford ranger witha 2.5L and latley the gas milage ihas been getting worse. It idles rought and is weak going up some hills. i have replaced all the plugs and wires a couple months ago along with a new fuel filter. Any ideas as to whats wrong with it?
Thanks
David
Old 05-05-2005, 06:04 PM
pintopower8's Avatar
pintopower8
pintopower8 is offline
The 2.5l's just a weak engine to start with. I average 20mpg with my 98 2.5l. Mine does alright going up hills though. Did you check the filter? Maybe a K and N filter will help.
Old 06-16-2005, 09:40 AM
Rngcnty's Avatar
Rngcnty
Rngcnty is offline
Lightbulb it might be the catalytic converter
You might wanna go to "muffler masters" or a place like that and get the catalytic converter checked. Usually they'll check it for free. I have an 88 ranger that was loosing power and gas mileage big time and it turned out to be the catalytic converter was in really bad shape.
Old 06-16-2005, 03:54 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome Rngcnty, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 06-18-2005, 07:12 PM
Ecuri's Avatar
Ecuri
Ecuri is offline
Or clogged injectors. I'd take a $10.00 roll of the dice on a bottle of techron.
Old 06-20-2005, 01:16 PM
pfogle's Avatar
pfogle
pfogle is offline
How many miles are on the truck? Is the CEL on? Did the plugs and wires cure the rough idle? If not replace the coil pack(s)...
Old 06-25-2005, 11:33 PM
RangerRuss's Avatar
RangerRuss
RangerRuss is offline
David: Does it "ping" going up hills?
As far as cleaning up your fuel and combustion systems - there is a thread in the Ranger forum which details how to "decarbonize" your engine. I personally have had excellent luck for years with a product called "Seafoam Deep Creep". It comes in both liquid and aerosol cans. I use the power brake line to introduce the product to the engine and intake. After the "soak" it will smoke like a chimney for a while and then stop. This tends to clear up a lot of ills. The aerosol is also excellent for cleaning up your throttle body - do not use carburetor cleaner as it has an adverse effect on the coating inside the body.
Give it a go and keep us informed. Were here to help.
Russ
djed
S. California Chapter
09-23-2012 09:12 AM
dwkremer
08-16-2005 07:27 AM
Davide33
20
12-12-2003 06:58 AM
bluemustang
06-10-2002 12:08 PM
dbarracuda
13
03-07-2002 09:58 PM
Quick Reply: 4 cylinder 2.5 with bad gas milage
