Seats in a 84
Seats in a 84
I was just wonderin if there is anyway to change the front seats in my 84 to another style from a differnt bronco. i want the style seats that are bucket seats with the middle arm rest with cup holders and mine are the bench with a split backin. Will they just fit right in or wont they??
Any seating arrangement that was available in the Bronco and F-series trucks will bolt right in to yours. Not certain about what changes may have occurred in mountings from year to year but the seat mounts are pretty generic for the entire F-series line. If there are mountings required for buckets that are not for the bench seating, the holes/mounts should still be there in the floor under the carpeting. Ford did avoid putting these in during the assembly process because they had no way of knowing which option which body would end up with. You would just need to come up with the bolts to run into the mounts.
http://img.photobucket.com/albums/v6...897_8_full.jpg
those are the seats i want. Will the center console also bolt right in???
