I found a Tach!
I found a Tach!
Hey y'all!
My dealer has found a instrument cluster with a tach in a salvage yard in Williston and I can get it for $100. Compare that to 350 bucks for a new one.
But the only problem is that the cluster mentioned above has 86K on it and I'm about to hit 81K in a while. What are my options?
Also, the guys at the dealer said I had to have a wiring harness setup for the tach if I put it in. Does my truck have the wiring harness in the dash for it or do I have to get one?
I need to get some answers on this. Thanks!
I would do that, but I prefer the clean appearance of the tach instrument cluster because I don't want to clutter my interior, and I absolutely don't allow any holes to be cut in the dash.
But that's cool that you did that. Did you have to cut holes in the dash or did you clamp it on the steering column?
Thanks!
Thanks!
Tach
Actually I just screwed it to the left side of the steering column. I bought a 2 and 1/8th inch unit, so it only obscured about half of the gas guage, and with that small of a tach you could just get a pillar mount for the A pillar. The only thing I didn't like was that it was not very bright at night.
Cduff
04-28-2014 03:33 PM
Handegard
02-22-2014 11:27 AM
Hog
15
02-01-2004 12:15 AM
