Drive Shaft Cross reference Chart
I recently had my M5OD stick replaced with a C6 Auto on my 95 F150 Extended and the mechanic cut down the front half of the 2 piece drive line instead of replacing it with the proper piece. I now have a slight vibration and would like to know what vehicles would have the correct front shaft. (Keep in mind 1992-96 F150s did not come equipped with C6) Would different years have the corrct lenth and diameter shaft possibley a Van ? What about converting it to a one piece unit ? Oh, engine = 4.9 I6. P.S., going back to the same mechainic is not an option because he kept my truck for 6 weeks and nearly cost me a divorce !
Thanks, Chet
Thanks, Chet
Yeah, those dents will cause it to vibrate, so replace the driveshaft or it will eat up u-joints like crazy. The C6 tranny was available in the 87-91 trucks, so look for one of those. The van driveshaft will most likely be too different to work. I also think that your wheelbase is too long for a 1 piece driveshaft since you have a supercab.
chetspencer
11-28-2013 02:37 PM
oldcoupe42
Electrical Systems/Wiring
13
10-10-2013 04:20 PM
oldcoupe42
07-16-2013 03:45 PM
oldcoupe42
34
07-07-2010 08:10 PM
oldcoupe42
07-24-2007 06:24 PM
