6.9 to 6.9 or 7.3?
6.9 to 6.9 or 7.3?
I have an 85 F250 4X4 with a worn out 6.9L in it. It burns alot of oil and knocks and rattles. I have the option of changing engines to another 6.9L out of an 85 2WD F250 or a 7.3L out of an 89 F250. Both motors are runable in the trucks they are in and will both need checking over before using. Which would be the better swap? Besides electrical what mechanical differences would there be if I went to the 7.3L? Clutch? All trucks are standard transmission. The 7.3L I believe has the 5 speed over the 4 in the other two trucks.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
jwolfe60
08-02-2007 05:28 PM
