best drive train setup for gas mileage
on
Mileage.
A lot will depend on brain power.
How will you drive the vehicle?
What size is it?
What are you using it for?
A 300 - 6cyl. will use more fuel at higher speeds than a 302.
The stroke is much longer.
Transmissions and differential gearing are another factor.
An overdrive transmission connected to a 3.0:1 differential will give excellent highway fuel mileage.
Common sense must enter the picture as well.
What size is it?
Full size trucks and good mpg (exc. diesels) are usually mutually exclusive. ;-) So if you want to save on gas and don't need a truck, drive something else instead. In any case, there are lots of things like terrain, towing, tire thread, gearing, city vs. hwy that can effect mpg, and an optimization that works in one case is may not good in the other.
The simplest and cheapest way to get good mpg is to be easy on the accelerator, and drive only when needed.
For your F250, put in an OD tranny and a fuel injected 351 *if you can*, else just use whatever is in there (tranny is probably C6) and use tires with highway thread, and try to find the optimum gearing ratio for whatever type driving you mostly do.
Geeeyejo
11-02-2014 08:20 PM
hallp82
1999 to 2016 Super Duty
07-22-2014 08:28 AM
fordfan758
10-31-2006 06:02 PM
