Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > Oklahoma Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oklahoma Chapter Join Chapter, Leader: Gary Lewis
  #1 (permalink)
Old 03-02-2005, 10:28 AM
okacookie's Avatar
okacookie okacookie is offline
Garage is empty, add now
okacookie is starting off with a positive reputation.
good alignment shop near norman?
hey guys i was going to see if there is a really good alignment shop in or around norman... i had my truck checked out at Sears yesterday when i went in to work and they said my camber was way off... which i new already... and said that i need to take it to an alignment shop. if anyone has a good place please let me know because i will have to get it done once i get the money. i use to use Big-O because thats where i got my tires but since i moved down to norman from yukon i dont really like the guys here... or atleast the ones i have dealt with. thanks a lot for the help guys.
chris
__________________
94 xlt bronco 5.8L automatic
  #2 (permalink)
Old 03-02-2005, 11:42 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader SwOkcOffRoader is offline
1952 Ford F-1
My Garage
SwOkcOffRoader is gaining momentum as a positive member of FTE.SwOkcOffRoader is gaining momentum as a positive member of FTE.
i dont know of any shops, ive never got an alignment done before, but im due now...........out of curiousity, does your bronco have the twin I beam set up?? if it does an alignment wont help, if it has the Ibeams like trucks do the only thing that fixes bad camber is replacing the coil springs....good luck......
__________________
Why is there never enough time to do it right the first time, but always enough time to do it again??
....Will work for Rep points....
  #3 (permalink)
Old 03-02-2005, 11:54 AM
okacookie's Avatar
yeah it has the IFS... so i just need new coils?
__________________
  #4 (permalink)
Old 03-02-2005, 12:03 PM
1952 Ford F-1
My Garage
i sent you a private message.......
__________________
  #5 (permalink)
Old 03-02-2005, 07:44 PM
Lobuck76's Avatar
Lobuck76 Lobuck76 is offline
Lobuck76 is starting off with a positive reputation.
The camber can be adjusted. There are bushings under the top ball joint that can be replaced to adjust. The ford service manual calls them camber adjusters. I replaced the springs on mine when I replaced the ball joints awhile back. It helped some but I still need to get to the alignment shop. Every place I've called has estimated 100$ to 150$ to align the bronco, Mine is also '94 Do a search in the bronco forum for "front end alignment" or "camber bushing" There are lots of threads with info.
__________________
'71 f100, 351W,C/6, ps,db
94 bronco,351w,auto
  #6 (permalink)
Old 03-04-2005, 03:45 PM
rogerf100's Avatar
rogerf100 rogerf100 is offline
rogerf100 is starting off with a positive reputation.
Unhappy
I had the alignment done on my 94 F150 2x4 at Sears in Norman. I had replaced the ball joints on the drivers side being sure to note the position of the camber plate for reassembly. I also changed the tierod ends. Unfortunately I waited a little too long before I got the alignment and have some excessive wear on the outside edges of the tires now. Sears replaced 1 bushing and aligned the truck for about $140. You could also call Reynolds Ford and get a quote on an alignment. Of course if it needs new parts that will cost more.
My truck had a bad vibration in the left front. I had a hard time determining if it was the ball joints or the tierods. I jacked up the front end and tried to move the left wheel rocking it top to botom and then side to side. I felt a little movement in the tierod so I replaced them first. Still had the vibration. So I borrowed a ball joint press from Autozone and replaced the ball joints on the left side. After I got the ball joints out I could see the bottom joint was loose. It was not hard to do just takes time and patience.
__________________
RogerF100
True blue Ford fan
'55 F100 with '64 292 V8 3 deuces
'94 F150 Flareside
roger dot hughes64 at gmail dot com
  #7 (permalink)
Old 03-05-2005, 04:24 PM
mr. dave mr. dave is offline
mr. dave is starting off with a positive reputation.
In the past when I've needed a front end alignment, I have used Ward's Frame shop in Moore. Haven't had it done for a long time, but I do remember he was the best and most economical in the area. Was very satisfied with his work.
Tags
alignment, alinement, city, ford, good, norman, oklahoma, shop, shops, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
