Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
- How to Change Brake Rotor
Step by step instructions for do-it-yourself repairs
How to remove Rotors that are rusted on Ford Expedition
#77
Might I suggest a flaming bacon oxygen lance?
FLAMING BACON LANCE - THEODORE GRAY | Flickr - Photo Sharing!
#78
About 18 months ago I replaced the brakes and rotors on my '01 Expedition. I did not think of the bolt idea. After trying everything but #2 dynamite over the course of a week, I downed 5 beers and took a lump hammer to the rotors and shattered them into small pieces. I put in those fake Halloween vampire teeth when I came back inside to impress my wife with my mechanical ability.
Well about 10K miles later I think the hub bearing went. All kinds of noise and vibration. So,,, I thought it would not be hard to get the rotor off as part of replacing the hub bearing. Wrong! I had to find the vampire teeth again and attack! attack! attack!. Then I read this. I bought two new rotors so I intend to take the other side off with rotor and hub together.
Great forum.
Great forum.
#79
#80
#82
take off rusted on front rotors
Have soaked the rotor inside and out a few times for about a week before I started to remove the rotors, all they do is flex out and after a few times of hitting and turning the rotor and tighten the screws they eventally screws strip out, I will just do the saw zall here, I know that works every time
#83
#84
The saw zall with new blades worked great! cut through outer ring and about a 1/4 inch into the rotor/hub area, cut a small little wedge on the outer ring so my chisel will fit in the cut rotor, about 3 good solid hits- the rotor broke into 2 pieces, 5 minutes and 2 new blades for each rotor.
Make sure you cut between the ribs on the rotor to reduce saw blade friction.
I will never pound on a rotor again for hours till it contributes to early wheel bearing failure.
Most times the rotors come off with a couple good hits, this is Michigan rust here.
I have used the saw zall a few times in the past to remove rotors.
Be sure to put anti-sieze on the mating surfaces if you want remove them easily next time.
#85
#86
Why didn't you just go to a junkyard and get another bracket? They're cheap enough and it's only 2 bolts to swap it out. The problem you can run into now is the pads will wear at an angle and your braking power is reduced.
#88
#89
#90
I am glad to see that many people are using the sawzall.
A guy at work just asked me how to get them off his navi... he was beathing the heck out of the front end, and was thinking about the bolt trick. Told him about my post a number of years ago... I'll repost it as it sounds like maybe it needs to be on the later pages?
