Rim Weight Capacity
Rim Weight Capacity
I have a 2004 F-250 and I am looking to upgrade my factory rims. My question is what is the weight capacity rating for the factory rims. I want to make sure that I at least get the same weight rating for my new rim so that it will take my 5th wheel. FORD cannot answer this question. Which is amazing to me based on the fact that they sell the truck. I was told by one of the tire shops that only forged steel rims will work for withstanding my 17,000 lb 5th wheel. These rims are around $300 a rim so I'm hoping that maybe this guy is just trying to sucker me and I don't necessarily need FORGED rims for my truck. I don't think Ford rims are forged. Any help is welcomed
Another question is that I remember seeing 04 Ford F-250 and F-350 right before the 05's came out with different types of rims other than the regular XLT and lariat rims. Does anyone know if these rims were 16" or did they move to the 17" right before the 05's came out? I'm looking at maybe just getting those rims if they are also 16". Let me know. Thanks.
The rims that probably came on your 04 are Alcoa's. They are hub centric...and I do believed they are forged...but I could be wrong.
If you want to replace the rims with similar features..you are going to be limited in choice. I do know that WELD Racing are Forged and Hub Centric.. I think there is a new company coming out called USA Forged or something to that effect..that are also Forged and Hub Centric.
The Ford Manual also states to use Hub Centric wheels...but then again it also says not to modify your suspension....(Whoops!)
This is how I understand it:
Hub centric wheels are a feature on newer vehicles. I'm not sure exactly when they came out. Older vehicles used lug centric wheels. People have been towing all this time with their older vehicles on lug centric wheels. The newer vehicles as stated came with hub centric...I don't know if the load/tow capacity increased as a result, but it would be interesting to find out. I also don't know if the lugs are different on newer trucks with hub centric wheels (ie..the design as it relates to structural integrity of the entire system for Hub Centric). If it is different (which I'm not sure of)..then I would guess that the load rating of a lug centric wheel on a truck meant for Hub Centric would really not mean much. I have heard of newer trucks fracturing a lug centric wheel...I don't recall the make of the rim, but I want to say it was a cheaper after market wheel.
What does it all mean? Well, if you tow a lot and tow heavy...I would get Hub Centric just for my piece of mind. Also if your vehicle is still under warrantee and you switch to a lug centric wheel...and have a failure that is related...Ford could choose to refuse warrantee work.
Thats what I've heard FWIW.
...whatever you decide...don't get a cheap cast aluminum wheel for your $45000 truck. Forged Aluminum is stronger and I believe the finish will also last longer. Cheap cast wheels are structurally weaker and will pitt and fade over time, especially in adverse weather conditions. Also be weary about cheap chrome wheels...do your research and make sure the quality is what you are expecting. Cheap chrome wheels can flake. It would be better to stay with your factory wheels under those conditions.
...just my opinion
...just my opinion
WE3ZS
02-27-2024 02:53 PM
JacoFordCummins
Engine Swaps
45
11-04-2020 09:09 AM
Neal 97 250
03-23-2011 11:57 AM
