Best mpg from inline 6?
Old 02-01-2005, 04:31 PM
Ol' Ranger's Avatar
Ol' Ranger
Ol' Ranger is offline
Just wanted to know what kind of gas mileage I could generally get from a 1992,standard cab, long bed inline 6 (300ci.)?
I've always had Rangers, 4cyl&6cyl and been happy with 20-25 mpg.
I had a 89 F-150 351that got all of about 11mpg,on a good day, without wind.
I didn't know if there would be much difference between the 6cyl. & 8cyl.?
Thanks for any info.
Ol' Ranger
Old 02-01-2005, 06:54 PM
the peppermint's Avatar
the peppermint
the peppermint is offline
efi gets a lot better gas mileage than my old 84 carbed setup, but i can get 14 city and 16 highway with 30 inch tires and a 3.08 rear end
Old 02-01-2005, 06:57 PM
dieselsaurus's Avatar
dieselsaurus
dieselsaurus is offline
This will depend greatly on the gearing, tranny and skinny pedal treatment. I have an '89 F150 4spd, 300, 3.08, 4x4. It gets an easy 17+ around town and through the country side - with moderate applications of acceleration. I also have an '89 F350 C6, 7.3 diesel, 3.55, 2wd. It gets around 16+. It doesn't matter if I go 35 or 65, empty of towing 10k pounds. Your 300 is just one variable in the greater formula. Most of these vehicles (when in proper tune) are good for mid to high teens. IMHO.
Old 02-01-2005, 08:25 PM
mattri's Avatar
mattri
mattri is offline
I got about 18 in an 82 Bronco, all stock with a 4spd, very "broken in".
Old 02-01-2005, 10:12 PM
Project Lazarus's Avatar
Project Lazarus
Project Lazarus is offline
I've never seen a common MPG # for 300s. I've seen them greatly vary, even for stock motors. For instance, my motor is all stock except for my exhaust. With 32" tires, 4.10s, and M5OD manual overdrive transmission, I'm averaging 7-8mpg mixed highway/city taking it easy on the pedal. When it had 31" tires, stock 3.08 gears, stock exhaust and same transmission, I think the best mileage I got was 12mpg, also mixed highway/city. You just can't tell with these motors.
Old 02-02-2005, 03:36 PM
Broncocustom1219's Avatar
Broncocustom1219
Broncocustom1219 is offline
I have a 1990 with 3" Gibson exaust a high flow cat, tb spacer and a K&N air filter and 33" tires with a stock rear and im getting 16-17 on the highway and 10-12 in the city. I guess for what i have on it im doing ok?
Old 02-02-2005, 06:29 PM
project supercab's Avatar
project supercab
project supercab is offline
Im running a 77 supercab 4x4 4.10 gear 35" tire 4 speed with a 4barrel and split exhaust manifolds 10-15 MPG and thats usually pounding it!!!
Old 02-03-2005, 12:59 AM
sierraben's Avatar
sierraben
sierraben is offline
I USED to average 20 mpg highway, with 23 being the best I got with a 1981 F150, 4.9L, T-18 trans, 2:75 rear end ratio and 215-75R15 maypop tires. I said used to. Now it's more like 17-18 hiway. That's because I changed the ratio to 3:50, put on a set Michelin tires (9.50 R15) on American Mag 10 spoke Vectors. Also threw in an Advanced Adapters Ranger Torq Splitter (27% o.d.). You can say my truck has 8 foward and 2 reverse speeds.
Old 02-03-2005, 12:03 PM
Sgt Wonderful's Avatar
Sgt Wonderful
Sgt Wonderful is offline
I get about 12 on a rainy day. Even after a fresh tune-up. My old 301 pontiac gets in the 20's. Both are 79 models.
Old 02-03-2005, 01:34 PM
wickymustang's Avatar
wickymustang
wickymustang is offline
My 95 shortbox regular cab, with the M5OD and 3.55 rear gets 20 or a little better (24 or so) on the highway and about 14-16 in town. That is with a bug deflector, moon visor, and open box.
Old 02-03-2005, 02:12 PM
Roushians's Avatar
Roushians
Roushians is offline
Awesome!! I really, really hope my 96 RC/LB with the M5OD gets the same as yours does (It hasn't arrived yet - shipped from KY!)
Old 02-03-2005, 11:53 PM
'961506's Avatar
'961506
'961506 is offline
How does that work??? MY bro had a '96 with no added wind resistance. 100% stock w/K&N filter and he gets 17 at best with recent tune-up and synthetic oil. He has the M5OD and 3.55 with 70/30 HWY/city mix.
Old 02-03-2005, 11:54 PM
'961506's Avatar
'961506
'961506 is offline
he also hardly revvs past 2200-2300 RPM too, what do you shift at?
Old 02-04-2005, 09:01 AM
wickymustang
Generally I shift at 2k, sometimes higher if I need to get moving in a hurry. I have a catback exhaust, paper air filter, tune up with plugs/wires/rotor/cap, castrol syntec blend oil, QS synthetic ATF, fresh gear oil in the rear end. I don't floor it to start off and I shift smart according to conidtions. Learned to drive stick from my dad, retired long haul trucker and have done a little semi driving myself.
Old 02-04-2005, 02:26 PM
Red2003XLT's Avatar
Red2003XLT
Red2003XLT is offline
You guys that are getting less than stellar mileage. What is your cruising rpm?
Quick Reply: Best mpg from inline 6?
