Block Heater trips GFI
I've had this problem with my 99 and now my 04. You have to pull the block heater plug outside of the truck to plug it in. Once and a while just from dripping or melting snow on the truck it gets the plug wet which in turn trips the GFI. I've thought about putting a small length of bike innertube over the plug on the truck end and zip tie it plus wrap with elec tape to stop the water from dripping onto the Plug. Anybody else have this problem and what was your fix. I like the block heater on cold mornings but like this morning it was 7 degrees and the GFI had tripped during the nite.
I had the same thing happen to me. I am a electrician and I just took it off the GFIC. In CT you don't need a GFIC for a truck heater. It is a good thing to do but the risk of shock in low. My GFIC failed and shot the cover off. 5-8 millamps is all you need to trip them. You can buy GFIC breakers with Variable Sensitivity. There are also in-use covers and snap on plug covers if you want try to keep the GFIC. Good luck
Casey
E-2
Casey
E-2
Casey I understand the GFI thing But I know the problem is water or another thing causing the gfi to trip. It only trips for the block heater nothing else. I just plugged it in tonite after doing my cheap fix. Every thing looked dry but it tripped the GFI. So out with the WD40 sprayed both plugs shook them off plugged it in and it worked. So I guess I'll see in the morning if it works.
I saw on the diesel stop (it's ok to post about other sites, right?) where a guy bought a Marinco outlet from a marine supply store and installed it on his truck. The outlet has a cover on it, and the install was very clean looking. I'm not sure if it addresses the issue that you are having or not, but you may want to try and search for it. He has some good pics available.
I found the write up here
I tripped my gfi while I was half asleep, running my snow blower the other morning. Yeah, you probably guessed it. I ran over the extension cord. Hadn't had my coffee yet. Boy, what a sight when I saw the snow jumping and flinging in front of me in the dark in the snow blower lights. Trashed the extension cord. Nice one too.
on
Rocknut,
I did not understand your GFI was tripping for no real reason. Any leak to Ground will also trip the GFI. This may be due to the elements leaking to ground. As our heaters get hot they may create a small capacitance (due to inductance) this would also trip the GFI. I'am out of ideas, good luck.
