1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Front hitch question
Old 01-07-2005, 01:31 PM
toypuller's Avatar
toypuller
toypuller is offline
Thinking about putting a front hitch on an 05 XLT.
Question: Does the instalation of the hitch require the front tow hooks to be permanently removed or are they remounted on top of the hitch plates that sit where the tow hooks bolt on?
Thanks in advance
Old 01-16-2005, 09:44 PM
BFR250SD's Avatar
BFR250SD
BFR250SD is offline
No. The only things that have to be removed are the front license plate bracket and factory fog lights, if you have them. Other than that, everything goes back on
Old 01-16-2005, 11:57 PM
reguy's Avatar
reguy
reguy is offline
BFR250SD is right, the hitch interferes with the factory front license plate mount.
I was just thinking of putting a front hitch on my F350 too.
Here's what I found...
http://www.etrailer.com/productdetail.asp?partno=5010&vehicleid=5566&yearf rom=2000&h=e
AND
http://search.cartserver.com/search/search.cgi?cartid=s-1547&bool=AND&category=dt_frontmount&maxhits=10&ke ywords=2000&keywords_2=Ford+F-350&GO=GO%21
Good luck!
reguy
Old 01-17-2005, 08:22 AM
toypuller's Avatar
toypuller
Thanks,
I have no fog lights or a front license plate bracket so no worries.
Reguy- that is the exact one I was looking at. Probably wait till it warms up a little and I'll get on it.
Old 01-17-2005, 08:39 AM
BFR250SD's Avatar
BFR250SD
BFR250SD is offline
Yeah, it's a real simple bolt on. I picked up a Draw Tite for about $130. You just undo take off the bumper, put the hitch on the studs, and put the bumper back on. I still had enough room to leave my front runner on. Plus it will give you about 1/4 to 3/8 of an inch spacing on your bumper. More tire clearance.
Old 01-18-2005, 05:31 AM
floorshow's Avatar
floorshow
floorshow is offline
Any photo's BFR?
Old 01-18-2005, 06:44 AM
BFR250SD's Avatar
BFR250SD
BFR250SD is offline
With the hitch on, no. The only thing that you see is the opening to the hitch. I have that mostly hidden by 4 KC slimlites on top of the frontrunner and 2 Maxtels that I hooked up in place of the fog lights when I took them out for the hitch. The 2 maxtels are spread out just enough to put a draw in the hitch. I originally put it on so I could put on a Warn Multi Mount Winch Bed, just never got the winch or the bed, so now the hitch just makes it easier to get my trailer down the driveway.
Old 01-18-2005, 09:21 AM
texan2004's Avatar
texan2004
texan2004 is offline
Warn makes one that does not require the removal of tow hooks or fog lights. With it, you do have to cut out a section of the air dam. I am considering purchasing one.
Old 01-18-2005, 09:36 AM
squan63's Avatar
squan63
squan63 is offline
ranch hand makes a front bumper with the reciever built in it and it has the cutouts for factory running lights and tow hooks . i put one of their rear bumpers on my 04 and am happy with it.
SatinBlack03
08-18-2016 08:00 PM
bronco6767
05-21-2016 04:17 PM
ligito
15
04-27-2015 05:21 PM
speakerfritz
16
01-18-2015 07:37 AM
damone
Toy Hauler Towing; Fifth Wheel & Bumper Pull
04-03-2004 02:32 AM
Quick Reply: Front hitch question
