I drove my F150 5.4 in second gear for 70 MPH and a whining noise came from beneat the truck like from the rear of engine ,Ipull over and stop the engine It will not turn over.
I thought that even if you shifted into 2nd, or even 1st for that matter, that the engine would shift anyway to prevent such a thing. Plus isn't there a rev limiter built into these things?
I wouldn't doubt if I've hit 70 in second while passing. If I jam on the gas I'm sure I can hear it dropping a few gears and with a 4-spd auto wouldn't that make it second gear?
Mmmm... I would play stupid and see what the dealer has to say about the truck not starting.
I know when down shifting the transmission won't shift into the lower gear until you are at a safe speed to do so. However, I believe you may do some damage if you start out in 2nd and accelerate to redline.
I drove my F150 5.4 in second gear for 4 miles at70 MPH and a whining noise came from beneat the truck like from the rear of engine ,Ipull over and stop the engine It will not turn over.
I was told the transmission frozen up and lock the fly wheel i was told by an ASE.
Can you tell us WHY you did that?????????????????????????????????????????
It was in that gear there by misktake and was chatting and paying no attenition until I hear the noise. tomorrow the mechanic is going to seperate the trans/eng and I will keep you inform. maybe looking for and engine anyone has one let me know or transmission found one eng.apprx 100.000 miles. price????
