1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
How to Remove a 5.4 engine?
Old 12-18-2004, 12:58 PM
78Explorer's Avatar
78Explorer
78Explorer is offline
Question How to Remove a 5.4 engine?
Hi All,
The more I think about it, the more I'm leaning toward replacing the engine myself in my 98 Expy. My brother-in-law has plenty of experience doing engine R&R's but not on an Expedition...
Will the engine come out of the engine bay or does the body have to be removed?
Have any of you removed a 5.4 from a 97-02 Expy? Any advice is GREATLY appreciated!
Scott
Old 12-18-2004, 09:01 PM
FTE Herman's Avatar
FTE Herman
FTE Herman is offline
They took the body off when they did mine. Much easier.
Old 12-18-2004, 09:18 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
If you have access to a good 2 post hoist then lifting the body is how I would do it.
If you don't have a hoist to use then yes it can be removed the "old" way.
If you decide to do it without lifting the body I would remove the inner fender liners to get at the sides of the engine. Also if you remove the front and middle body mount bolts you can raise the front of the body up a few inches to make it easier to access the bellhousing bolts and wiring at the back of the engine.
Old 12-19-2004, 03:49 AM
78Explorer's Avatar
78Explorer
Thanks guys!
Unfortunately, I don't have access to a hoist to do the body lift...guess I'll have to do it the "old" way or pay Ford garage $1100 to do the swap for me...which, the more I think about it, probably isn't a bad price to let someone else deal with it.
Old 12-20-2004, 12:19 AM
bubahyde's Avatar
bubahyde
bubahyde is offline
I used to do alot of those. In F150s mostly but we did do as couple expeditions.
The motor will come out the top but you will need to remove the intake. The engine sits so far back that it will not come up enough to allow it to come forward. We made plates with a eye hook in the middle (Lift Point) and bolted it down were the Intake was.
expy37at
34
04-08-2024 06:24 PM
Mark T-TB
07-27-2010 02:15 PM
frankgant
19
07-13-2010 11:00 PM
quick35th
36
08-15-2006 12:39 PM
97expy5_4
04-27-2003 09:13 PM
Quick Reply: How to Remove a 5.4 engine?
