17" to 18" Tires
17" to 18" Tires
When I recently purchased my 04 XLT 2x4 I had them upgrade the wheels to a set of Lariat wheels they had just taken off a new truck. This took me from 17" to 18". The service manager said the difference was so small I did not need to reset the computer for mileage. Others have since said I should have. Does anyone have experience with this? What would you do?
https://www.ford-trucks.com/user_gal...oid=63127&.jpg
Not knowing what size tire came off, I will assume that the standard XLT tire 235-70-17 came off. The Lariat tire size is 265-60-18. If these assumptions are correct, the original tire 235-70-17 provides 673 revs per mile, the new 265-60-18 now provides 661 revs per mile. I think this is substantial enough to throw off your speedo.
BTW here is a tire size calculator to help:
http://www.miata.net/garage/tirecalc.html
Hi JiffyJam. The lariet tires I just put on are 265-60-18. 1.25 inches larger in diameter than the 255-65-17 tires I just took off. 1 percent difference. Rather than adjust the speedo with my Superchips, I'm going to leave it. My speedo ain't all that accurate. This will make it closer.
(excuse to get a programmer?)
Chris
Chris
Very interesting, I just changed my stock FX4 tires,today in fact,(255 70 r17) to FX4 optional take-offs(275 65 r18).According to Miata calculator(great tool KevinM) mine would only be off 3.3%, reads 60mph=actual 62. Not significant enough for me. Great question and responses though!Thanks!
Originally Posted by Scott_XLT
jiffyjam -- I checked out your truck pic. GREAT looking truck. Where did you get that awesome front grill?
( The shine is from using Zaino Show Car polish, its hard to beat. Try their website.http://www.zainostore.com/Merchant2/merchant.mvc
CORRECTION. Boy did I goof, and just noticed it. The 265-60-18 tires are 1.25 inch CIRCUMFERENCE not Diameter. Hoo-boy. The diameter is .4 inches larger.
Tracking with my GPS the speedo is now only over reading by 1.2 miles an hour, not the original 3.6 at 70 mph. So actually it's closer to right.
Chris
Chris
downsize tire swap
