'40 starter button
Old 12-31-2004, 10:38 AM
Lazy Hog Farmer's Avatar
Lazy Hog Farmer
Lazy Hog Farmer is offline
'40 starter button
My wiring diagram ('40 Ford Pickup) shows the starter button grounded to the cab. I have a new ground strap from cab to engine. Continuity is good. I ran a wire from the start button to the terminal on the starter solenoid closest to the positive cable - nothing. I then ran a hot wire to the button and figured that the grounded dash would complete the circuit. When I hit the button ' it smokes so it is obviously going to ground. If I isolate the button from the cab (dash) and use a return wire from the body of the starter button housing to the solenoid, it works like a champ. My solenoid (starter relay) is a more current unit from the mid sixties. Anybody care to venture what I need to do to make it work with the button in the dash? Thanks, Steve
Old 12-31-2004, 03:23 PM
41inWV's Avatar
41inWV
41inWV is offline
I experienced a similar problems on my '41 initially. Be sure the momentary button (starter button) is properly installed. That metal dash can cause issues, then in a worst case scenario take a ground wire clear back to your battery ground.
Not exactly sure how you're wiring is i.e. original harness etc, but I created a single source known good ground point under my dash, also an 'accessory' hot and a direct hot point. I have installed new VDO guages, and grounded them to each other and then to the single known good ground. Your switch could ground to a single source like that too.
Hope this helps
Old 12-31-2004, 04:40 PM
Lazy Hog Farmer
Thanks, 41 By properly installed, I assume that you mean that the start button fits snugly in the dash. This could be the trouble as it is a little loose after being in and out of the dash so many times. If I were to run a separate ground to the battery, I think you mean that the ground wire should be affixed directly to the switch housing and not the dash? Steve
Old 12-31-2004, 05:25 PM
41inWV's Avatar
41inWV
41inWV is offline
Thats exactly what I meant.....sorry to be a little unclear. Sounds like the loose fit in the dash may well be the issue. I replaced my button with a new one....probably about 7 bucks or so at any auto parts shop..
Old 01-06-2005, 08:12 PM
41Clay's Avatar
41Clay
41Clay is offline
The newer starter soliniod may be the problem. The origional used the button as a ground to the soliniod to start the truck. Newer ones use a hot current going into the soliniod in order to start the truck. You may be able to attach a relay into the system so that the starter button will work (although when I tried that with my 52 and got a jolt of pain everytime I pressed the button). Good luck!
Clayton
Old 01-07-2005, 11:08 AM
Lazy Hog Farmer
problem solved
Thank you guys, for your input. I received a comprehensive email from the member from another forum. In it he explained about the need for a grounding relay. Steve
Old 01-07-2005, 03:11 PM
51ford fan's Avatar
51ford fan
51ford fan is offline
I installed a new Ign. switch and wired it in just like the late model trucks. The starter button is just there to fill the hole in the dash on my 51.
gtotiger65
06-21-2015 01:35 AM
oldford54
06-28-2014 12:59 AM
chappys4life
06-29-2012 12:05 AM
1951flatheaddave
19
12-01-2011 10:53 AM
Ultimatequinoxe
Electrical Systems/Wiring
13
10-06-2011 06:08 PM
Quick Reply: '40 starter button
