V. Fix on the way?
V. Fix on the way?
Friday before Thanksgiving week, left my f150 at the dealers to have a new drive shaft installed (fix for vibration). Well...........a week later I returned to dealer only to discover that NOTHING had been done...nor had they tried to call my house (I was out of town).
It seems that they ordered the driveshaft from Ford but got a last minute... "STOP EVERYTHING" order from Ford. They claim that Ford has told them that there is a new fix on the way and it will require additonal parts. Now exactly what "on the way" means............supposedly........in a week or 2. Hmmmmmmmm
The dealer service manager apologized and said that they would contact us as soon as the new "vibration cure" is sent to them . Of course........we need to tow our camper over the holidays and silly us.....don't want to pull it by hand.
AAAAAAAAAAAAAAArgh.
So........is ther a NEW fix on the way?
Dealer says he has several trucks in the same spot.
AAAAAAAAAAAAAAArgh.
AAAAAAAAAAAAAAArgh.
AAAAAAAAAAAAAAArgh.
rick
Thank God I don't have the vibe, but I REALLY hope Ford does some out for a cure very soon for the people who do have the vibe! I hate seeing everyone so mad and dissopointed at there trucks due to the vibe, and it would be great when ford does fix these trucks of the vibe to have nothing but happy f150 owners!!! These trucks are the best trucks on the road!!!!!
THE CURE IS A LIGHTER DRIVESHAFT! I just spent over $800 on a carbon fiber driveshaft b/c my vibration was amplified with my 4.56s. With a 14.5 lb shaft over the 30 lb stocker, I have NOT ONE vibration. Any and every virbration at any speed, even when the truck was stock with the infamous 45-60 mph vibration range, is GONE. SO, if they are replacing your driveshaft, see if Ford may have come out with an aluminum replacement like th 5.4L pre 04 trucks had. Just balancing or replacing the heavy stock steel shaft will most likely NOT cure you completely. You cannot spin a 30 lb, 70" long shaft that fast without getting a vibration at some point. Some are worse than others, but even those who claim they have no vibrations would notice the truck being smoother with a carbon fiber or even aluminum replacement.
the "cure" for some might be the driveshaft, but my vibration lies within my engine, 500-800rpm and the from roughly 1700-2100rpm at a constant rpm.
AHHHHHHHHHHHHHHH!!!!!!!!! I swear!!!!!! I just Jinxed myself writing my frist reply to this forum! I just said thank god I don't have the vide, and what do you know.........IT HAPPEND TODAY TO MY TRUCK!!!!!!!!! Driving home on the highway at 70mph I started to feel the vibration through my wheel!!! I am so ****ed! I took it right to the dealer where I test drove it and had my dealer verify the vibration which he did! Now it's sitting in the dealer!! I can't believe it! 1,300 miles on it! Someone shoot me!
i spent this much...
You can dynamically balance any shaft. Drive shafts on cruise ships are the size of buildings and they're dynamically balanced to within ounces.
I too am waiting for the magical fix for those of us with vibe problems. I had my truck in the dealer October 29th for the third attempt at fixing the problem. The mechanic I spoke with said that he had contacted Ford engineering since the current TSB had already been worked to the letter. They advised him to install a "known good driveshaft". Well he did have one on hand, installed it and it slightly improved, but no where near fixed the vibe.
So long story longer, he said that at this point Ford advised him to "stop work until a revised procedure and parts becomes available". He said they told him it would be late November, early December.
I have not heard any dates except what I've read on this forum so I really appreciate you guys that have heard dates posting them, thanks!
Please accept my sincerest apologies for my grossly incorrect statement assuming everyones problem is the drivesahft. HOWEVER, the overwhelming majority of people with the vibration is speed related not RPM, so you may have an improperly balanced engine, bad motor mounts, or just a POS. SO, to correct....if your vibration is speed related, IT IS YOUR DRIVESHAFT! Ford dealerships waste thousands of Ford's money replacing everything but the driveshaft, and from what I have seen, none of these fix attempts like the damper, new ring and pinion, ect. ever do anything.
AAAAAAAAAAAAAAArgh.
AAAAAAAAAAAAAAArgh.
I have my DSB hearing this week. In my paperwork from Ford it says a series of fixes for the vibration are to start being released in early December. That's the first I've heard about it. They never contacted me about it.
If your truck is like mine it feels dangerous to drive when hauling anything. I haven't towed anything with mine. When I hauled firewood in it the vibration was amplified throughout the vehicle and felt difficult to control. My truck is useless. Good luck with your truck. I wish you the best.
