79 F150 4x4 Ignition wiring
Old 11-30-2004, 04:24 PM
luckytruck79's Avatar
luckytruck79
luckytruck79 is offline
in my 79 f150 I need to find a wiring diagram for the igniton system. I was also wondering if anyone knows how to test the ignition modules. Any help would be greatly appreciated. It originally had a 300 I6 in it.
Old 11-30-2004, 08:19 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
Old 12-01-2004, 03:43 PM
73Custom's Avatar
73Custom
73Custom is offline
Most any parts stores will test the ignition module for free.
Marty
Old 12-03-2004, 09:35 PM
luckytruck79
I installed a new module anyway, cuz they always go bad. I put it on, ran for a couple of days. Now today it died without spark at work today. I ran all new wiringfor the ignition system from the module to the distributor and coil. The wires were getting pretty old do I needed to do it anyway. Still nothing, and the coil is good. There is power to the module. I think it went out again. No parts stores around here can test them. And we have almost have every parts but none say they can test them. Oh yea, I tested the wire to the oil pressure sender and it was pulseing. Wierd, the gauge worked though.
Old 12-03-2004, 10:08 PM
Franklin2's Avatar
Franklin2
That's normal. The guages are fed by a voltage regulator that pulses the voltage.
the coil is good
Do you have power to the + of the coil with the key on?
Do you have pulsing power on the - of the coil when you crank the engine?
nothercrash
02-27-2014 08:49 PM
Manchester79
01-10-2013 08:54 AM
HatleyT
07-06-2012 11:40 AM
blkmesamtman
10-01-2011 02:33 PM
muddawg
Electrical Systems/Wiring
03-31-2002 09:02 PM
Quick Reply: 79 F150 4x4 Ignition wiring
