2004 SD 250 pickup. AC quit. The compressor clutch will not activate. Fuse good in panel, voltage at compressor OK. Looks like the a new compressor. Any ideas before I have to take the unit in for repair?
You may have a leak and the pressure is to low for the compressor to engage, there is a low pressure cutoff switch that keeps the compressor/clutch from working when the freon charge is low.
Does sound like a clutch problem but I would check the gap between the clutch plates. Not sure what the spec is on your application but if gap is too much clutch won't engage. You say it's a 2004, is the warrenty out? If not, let the dealer have the headache instead of you!LOL Hope that helps. Carl
