Colorado Chapter Join Chapter, Leader:
Dealers??? Help
Old 11-30-2004, 05:42 PM
GX2's Avatar
GX2
GX2 is offline
Arrow Dealers??? Help
01 F350 Power Stroke XLT
Dieing and stumble on Highway.
No Check Engin Light to Diagnos
Dealers have no Clue.
Any Sugestions??
Thanks For the TIME.
Old 11-30-2004, 07:47 PM
mattri's Avatar
mattri
mattri is offline
Where in Colorado are you?
Old 12-01-2004, 09:57 AM
Mike G's Avatar
Mike G
Mike G is offline
First off GX2, welcome aboard!
Secondly, you may want to check in with the PSD forum group, propably get a better answer than what I'm about to say..... How about water or moisture in the fuel system
--Mike
Old 12-01-2004, 10:07 AM
Colo79Ford's Avatar
Colo79Ford
Colo79Ford is offline
Might want to find something to clean youre injectors aswell....if you dont find anything you wanna buy, try running a quart of ATF thru the fuel system in your next fill up. The ATF should help clear anything out of your injectors that may be causing them to be restricted..
--John
