1978 - 1996 Big Bronco
Engine Missing
Old Nov 17, 2004 | 04:55 PM
mspence's Avatar
mspence
Cool Engine Missing
I have an 89 with the 5.0. Two days ago I took a 40 mile trip and when I exited the interstate and came to a stop the truck was vibrating very noticeably. In neutral and park at idle it runs fairly normal, under load or above idle it vibrates. I am assuming it is missing out. I changed the plugs, wires, cap and rotor and this did not correct the problem. The funny thing about this is that when I am at highway speed the vibration is not there. No check engine light on since I bough the truck. Any ideas?
Thanks
Matt
Old Nov 17, 2004 | 05:14 PM
greystreak92's Avatar
greystreak92
Dirty or clogged injector or fuel filter perhaps. Might pull codes even without the check engine light just to be sure.
