Lightning brakes
Lightning brakes
Hope someone can help with a front brake question. I want to upgrade my front brakes on my '97 F150 to Lightning components. The most obvious difference is the rotor width the L is about an 1/8" (4mm) thicker. This causes the caliper alignment to be different. So, is the caliper mounting frame different, or the frame and the caliper, or the steering knuckle, or all? Are all gen 2 lightning front brakes the same? I know the stud size changed, anything else? Thanks!
