5 ltr with aod into 67 f100
AOD in 67 PU
I put an AOD in my 68 Mustang behind a 302. The trans will not work without the trottle position cable and will burn up quickly if it's not adjusted correctly. Lokar sells a cable and brackets to hook your carb up to the AOD like you need. You will have to adjust the lenght at idle while checking fluid pressure from one of the taps on the right side of the trans. Or you can get a transmission shop to hook up their gage to adjust the linkage. I have 4.11 gears in the old stang and the AOD is great.
By the way, I have a 67 pu that I plan to drop a EFI 5.0 and AOD into next year. Let me know what you are doing for motor and trans mounts. Thanks.
mebe2k
12-28-2010 06:35 PM
ellery
12-06-2003 10:11 PM
