Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-03-2004, 07:49 PM
scottie2hottie's Avatar
scottie2hottie scottie2hottie is offline
Garage is empty, add now
scottie2hottie is gaining momentum as a positive member of FTE.
Question Flathead specification questions.
I was reading up a little on flatheads, and found a site that manufactures custom Flathead heads(sharp heads) with your choice of Chamber Volume anywhere from 53cc to 80cc. This got me thinking....What were the stock CR and Head Chamber volume of a 239 flathead? What kind of pistons(ie dome, flat) were used from the factory. Lastly, what kind of CR can a Flathead block SAFELY take?
Thanks
Scott
__________________
2002 F350 "Big White"
2001 F150 "Black Pearl"
1996 F350 "Red Sled"
Proud to be an OHIO BOY
  #2 (permalink)
Old 11-04-2004, 12:41 AM
Rancheroracer Rancheroracer is offline
Rancheroracer is starting off with a positive reputation.
I had a 51 Ford Victoria with V8 flathead. The stock pistons were flat tops. Stock compression on the 49-53s was 6.8 to 7.2. Check out this site:
http://www.vanpeltsales.com/FH_web/f...0to125late.htm
__________________
2012 F-150 XLT SC Ecoboost Tuxedo Black 6.5' bed 4x4
I can do all things through Christ who strengthens me. Phillipians 4:13
  #3 (permalink)
Old 11-04-2004, 05:45 PM
Thank you!
Scott
__________________
Tags
custom, flathead, heads
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
