That annoying door chime is finally quiet!
#31
Originally Posted by cookie88
It does not work on the earlier ones (2001's included ) however, we can simply push the release button on the seat belt latch and it shuts it off for that drive cycle......or unplug it.
Austin
#32
Originally Posted by mech2161
Kwik will your remote door locks work now with the key in or running since it doesn't detect it. Wish I could lock mine with the remote and leave it run in the morning. You know the first stop is only 2 blocks away. Need my cafine fix MTNDEW.
#33
#34
#35
"Right on! Did you remove that annoying trigger for releasing the key too."
They are only on standards, I don't think automatics have them.
You shouldn't have to pull the plastic on a superduty to get to the poke hole for the ignition,there is a hole in the plastic for it. Just make sure your in the run position. If yours doesn't want to come out. press on the retainer while turning the ignition to the run position and you'll feal it go in.
#36
#39
#40
#41
Mr Kwick you are the MAN.(Once Again) Not only worked on the '99 SD but on the "05 Ranger and to an extent on the "97 Crown Victoria (Don't chime with door open except when in acc.) Those D*** chimes were driving me CRAZY in fact on my work truck I ended up cutting the door switch to get rid of them so I could hear my work radio. Guess I'll have to fix that and do this mod.
Eckart, yes you can get the ignition switch out without taking the cowling off but you cant slide the connector out of the hole.But thanks for another option.
Hope all have a great weekend even with the high Diesel\Gas prices.
LPR
LPR
#42
Originally Posted by BillC
why are people so f'in STUPID...?
Boy, the other day I got jumped on for saying something that wasn't even close to this! Selective censorship? I wasn't even talking about gas prices!
#43
hey anybody got the wiring diagram for the OBS door chime why do they have 7 wires going into that stupid thing.??? im wondering if i can set it up so i dont get the door chime with keys in but still get the light chime.....or i may have to put a photocell and a relay and make my headlights auto on when it gets dark....
#44
#45
i was expecting to see voltage on the pins only got it on one no matter what i did so i take it the switches that make the chime come on ground out..i was thinkin of just putting the chime ground on a switch so when i have my door open and dont want the chime i can just switch it off. with no chime i wonder how many times im gonna leave my lights on or lock my keys in my truck. although my ball of keys it might be kinda hard to forget thoose getting out of the truck.
