351W to a 351M
you will have to change the trans bell housing...351M is a big block bolt pattern , the 351W is a small block bolt pattern...
why on earth are you switching a 351w for a 351m? if you are going to go thru the trouble just go with a 400M or a 460. or you can use a 351C and all you'll have to change are the exhaust manifolds or use headers. you are not accomplishing anything by going from a 351W to a 351M except performing a lot of usless work.<<< just a thought!
92",F-150, swb, 4X4 351W (365)HP E4od project truck.
I've got a 78 F-350 dually, with a 351M stroked to 400 cubes, and I agree. This truck has power to spare with a low to mid torque cam and a 2v carb . It was'nt built for speed, but hauls _ss to boot. I use it to haul a 12k trailer. Thought about selling it, but it runs to good. My hot rod in disguise.
I would agree and listen to to those guys suggestions.
Good luck, Hobo.labo
Originally Posted by stevef100s
Matt, with those mods you mentioned, and the Aussie heads, I think a 400 would be a little closer to 450 hp. But more is better, right?
Right now, I've got a 400, bored .040" over, a Comp 265DEH cam, Crane Scorpion Roller Rockers, 1 piece valves, ported 2V heads, Edelbrock 2171 hi rise dual plane intake, a Demon 625 Road Demon 4V, Tim Meyers Flat Top pistons (9.5 :1), and Doug Thorley headers. Supposedly this is 435~ HP, and 465~ Ft/Lb. I will verify it when I get it on a Dyno, one of our customers has a high performance Diesel shop, and they just bought a Dyno to test the truck on, I think he might let me run on it. It might not be too soon, I still have axles to swap and a 9" lift kit to put on.
not to hijack the thread or anything
