Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Advertisement
  #1 (permalink)
Old 10-06-2004, 06:00 PM
eddie3 eddie3 is offline
Garage is empty, add now
eddie3 is starting off with a positive reputation.
max tire size on F350 dually
Whats the biggest I could go with. It is a 2wd crew cab long bed dually, V10.
  #2 (permalink)
Old 10-06-2004, 08:48 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1997 Ford F-350
My Garage
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Depends on how much you want to spend to keep the required dual spacing and clearance. I have seen 315/75-16 tires on a dually, but he spent 500 dollars for the spacers to do it and also had a 6" lift on it. It was a 2003 F350 4x4 PSD dually.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #3 (permalink)
Old 10-06-2004, 08:52 PM
RedTaurus94's Avatar
RedTaurus94 RedTaurus94 is offline
RedTaurus94 is starting off with a positive reputation.
I run LT265-75-R16E Firestones on my dually. These are 1.18" wider than the stock LT235-85-R16Es. There is a gap about 1 inch wide all around the tires, EXCEPT down at the bottom, where the tires are spread out. Down there, the gap is only about 1/2" - 5/8". Your best traction will be with the narrowest tire you can run, but wider tires look better, I know. 275 series tires would be about .4" wider, so they might actually fit onto the truck, but they would come mighty close to touching. 285s would definitely touch each other. To fill up the wheel-well, a taller tire would work. My 265s are virtually the same height as the stock size since they are 75s instead of 85s. To figure out what size tires you want, just do the math yourself:
First, convert the metric tire width to English:
265mm / 25.4 = 10.433 inches
or
235mm / 25.4 = 9.252 inches
The 75 or 85 means that the sidewall heights are 75% or 85% of the width, so
10.433 inches x .75 = 7.825 inches
or
9.252 inches x .85 = 7.864 inches
To calculate the tire height, just double the sidewall height and add the rim size:
2(7.825) + 16 =
15.65 + 16 = 31.65 inches
or
2(7.864) + 16 =
15.728 + 16 = 31.728 inches
(see that both of these tires are about the same height?)
Get a number in mind, do the calculations, and then search to see if your favorite tire maker makes the size you want. If not, then you can see what their closest offering is. Remember that a tire that is 1 inch taller will only fill up an additional 1/2 inch because the tire will be 1/2 inch bigger at the top, and 1/2 inch bigger at the bottom. Also, if traction in snow is important at any time, then you might want to think about going as narrow as you can stand.........
__________________
'02 EXPLORER XLT 4.0L
'00 F-350 XLT PSD CrewCab LWB DRW 4x4
'94 RANGER XL SuperCab 4.0L 4x4
  #4 (permalink)
Old 10-08-2004, 09:16 AM
Well I wasn't planing on lifting it, just keeping the stock height and put a locker in the rear. Thnks for the info.
Tags
2004, 315, 75, dually, f350, fits, ford, max, original, size, sizes, stock, tire, tires, truck, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
