2.3L OHC Topaz burning oil
1987 Mercury Topaz with 2.3L OHC engine.
I haven't yet determined how much oil it is loosing but appears that more than normal. Probably 1qt/ less than 1000 miles?
It has 106,000 miles on it. I drive it fast, and aways at 3,000 RPMs. It is a 3-speed auto with no overdrive.
Questions - what's the longevity of this engine, what should I expect? It appears to be worn a bit at that mileage. Though it runs very well, no problems with anything. Nor do I see any leaks.
The major thing to watch for is cracked heads. KEEP THE COOLANT FULL!!!!
A quart in 1000 miles is not excessive, and is a lot cheaper than rebuilding or doing cylinder head work. FoMoCo will not touch a NEW engine that uses less than a quart in 700 miles, so you are above the 'new' limit right now, and have 106K miles... at least that WAS the old standard.
The engine will last at least another 60K if you don't blow it up, keep it watered and oiled...
tom
tom
I just drove about 400 miles and added about 1/2 quart of oil. A lot of that trip was at 3500 rpms. I don't know about 2.3 but my big 7.5L engine burns more at higher rpms.
It does burn it significantly.I looked at PCV valve and it appeared to be ok, I could shake it in there.
It does run well on the other hand. Enough power once you get to 3,000 rpms.
68Mercury250Ranger
4 Cylinder Engines
05-16-2007 11:48 PM
GT 150
Ford vs The Competition
46
12-26-2003 01:37 PM
