I want to put grease in driveshafts before the winter comes but where is the zerk or some kind of plug in then pump the grease into driveshaft or u joints??
If you don't see any zerks, then the u-joints are sealed and you don't have to worry. The factory u-joints are usually this way but the replacement types sometimes have zerks.
i see.. i kept read posted about clunk and noise in driveshaft and there is TSB for it and some mention about add grease by TSB dealer to it so thats where i want to fix/grease it before winter comes.
That's referring to the slip yoke--the splined front section of the shaft which interlocks with tailshaft of the trans. Some of the users have mentioned that a teflon type lube is used on this.
