spring removal
spring removal
need help with front of rear spring removal. the manual says to us a drift through the hole in the frame to drive out the pin. the hole is there but there is a crossmember brace in the way.has anyone got a solution as to how to get these pins out? by the way this is a 49 merc m47
Ditto to all of the above. The one thing I would add is that rotating the pin ever once in a while when shaking the shackle during the extraction process helps also. It seems to get the shoulders past the bushing edges.
The slide hammer idea worked on 2 out of 4 for me. Pounding out the pin thru the frame access hole worked on the third. On the 4th one, I had to cut the spring, grind off the rivets, remove the fitting and press out the pin. Good thing I was replacing the springs anyway.
Oh yeah. Use a big hammer.
