Specifics and 8.8" Explorer Install
#31
I went to Sids in Glencoe and found a set of lower anchor plates with a shock mount saves welding new ones on. Sid thinks they are off a Dodge. Since I had the rear end there I dropped it off and he is going to plasma cut the old perches off and grind out the new ones he has to fit the 3.25" axle. He is also ordering u-bolts he did not have any that short. I should be able to pick everything up tommorrow. Hopefully it will be together this weekend. I am also going to get him to do the drive shaft for me.
#34
#35
Parts from Ford would cost a mint.
Go to www.car-parts.com and enter in 96 ford explorer V8 3.73 is the most common ratio. They start at around $100, they are a dime a dozen because explorers don't last.
#37
Sway bar is up to you, but I wouldn't bother on a solid axle pickup. Other than that you need the standard axle swap stuff - U-bolts, spring plates, spring perches, gear oil. You also want to get the driveshaft off the donor vehicle, exploders use a retarded flange mount on the diff side that is hard to get anywhere.
#38
#39
so all i need is the rear end and drive shaft, nothing else?
i found a guy that has one out of a 95 with disc,3.73, and he wants $200
but i just need to know if i need anything else so i can bargain and get all i need with out takeing things i dont need and have to trow it out later
#40
OK, OK, GEt the e-brake cables if you are not going to buy the Gennie or Lokar, Get the brake lines with the hose not cut co you can just hook right up to your 3/16" hard line. Real easy. Get the u-bolts, get the nuts, get the plates,get the stablilzer if your tank is not in the rear, get all you can.
I would get the driveshaft if you need one. The flange for this unit is NOT hard to come by. Your DL guy should have many laying around. Mine cost 10 bux. The whole job cost 100.00 and 1 day,it was even painted.Get the bolts ( 4 ) to fit the flange. This is so easy of a task that I am curious why this thread is sooooooo long.
#41
#42
Hey Twisted56, Just seen your gallery, I Likeeee.. Your ride is drool inducing. I envy you for sure. Anywho...I am near Pecos/ I-36 and I welcome all to my work space to come benchrod and learn/share anytime. Bring your camera if you like. I Don't work so, you can come by anytime. Email is checked in P.M.
Gimmy yer truck............
#44
