Superchips Custom Microtuner for Escape
on
A. It plugs into the diagnostic port located under the driver's side dash. Follow the on screen instructions and then unplug it.
B. No need for a chip... it won't work with a chip installed.
Cost ---
Tuner: http://www.motorhaven.com/customer/p...cat=274&page=1
Diablo chip:
http://www.motorhaven.com/customer/p...&cat=37&page=1
Superchips Custom Tuning chip:
Cost ---
Diablo chip:
What you have to remember is that it is easy for a dealer to void a warranty for having a chip. With a SCT Tuner or Predator that plugs into the diagnostic port it is much harder to trace. With a chip, all the dealer needs to look for is the conformal coating scratched off of the computer I/O port (where the chip plugs in).
Also, I've had problems with chips being loose or not making perfect contact and causing some temporary problems (not starting, irradic idle, etc.). This happened especially when it is cold out.
on
on
I didn't say the conformal coating isn't there on every processor (which by the way, isn't true... older PCM's use a white grease). Letg me try again:
When you clean the connector with the included Scotch-Brite pad it leave scrape marks on the connector. That is usually the give-away. Acetone wipes it off clean and leaves the connector shiny... and it doesn't look much different then it does with conformal. You can pick up conformal-like coating at electronics shops. Connector with conformal and no scrapes equals stock.
What I was getting at is that the they can still tell thru the PCM if any of the programming has ever been altered. I know that the tuner holds the original programing so that it can be re-installed. I had a SCT for my 97 Powerstroke. But service techs tell me that they can tell if it had a tuner on it, even if the stock programming has been re-installed.
