Need Help
Fordman, do your dash lights dim when you try to start it? If so, you may just have a low battery, and need a jumpstart. If that gets it to start, but then you keep having this problem, you might have a bad battery or alternator. Also, if that's the case, before you change the battery, be sure to make sure the cables on it have good, clean connections - that's a simple fix, sometimes.
PS - if you title your posts descriptively, such as "Clicking sound, won't start" or something like that, rather than "need help," you'll probably get more help. Don't worry, you'll get the hang of it soon enough!
Ryan
Ryan
