Colorado Chapter Join Chapter, Leader:
Need an engine...
Old 09-09-2004, 11:53 PM
XFracture's Avatar
XFracture
XFracture is offline
Need an engine...
Looking for an engine for my truck, its blowing oil out the tailpipe (in the form of smoke), so it won't pass CO/Springs emissions tests...
Anyone got a working V8 engine, that is not smoking for sale? I would prefer an FE, but I will consider any Ford V8 so I can actually use my truck...
Old 09-10-2004, 09:13 PM
mattri's Avatar
mattri
mattri is offline
What year/model if your truck?
Old 09-10-2004, 10:14 PM
XFracture's Avatar
XFracture
'65 F100, 2wd, 4 speed
Old 09-10-2004, 11:27 PM
mattri's Avatar
mattri
mattri is offline
And I'm assuming you're running an FE now?
Old 09-11-2004, 02:47 AM
XFracture's Avatar
XFracture
yep FE 352
Old 09-11-2004, 08:20 PM
mattri's Avatar
mattri
mattri is offline
Give me a day or two, I may know of something.
Old 09-13-2004, 05:34 PM
XFracture's Avatar
XFracture
cool...
Old 09-13-2004, 07:34 PM
mattri's Avatar
mattri
mattri is offline
Buddy has a complete 400, carb to pan. Runs well, good compression on all cyls. The bell housing is different for your motor but he has that as well so you can bolt it right up to your 4spd. PM me if you are interested.
Old 09-14-2004, 04:07 PM
Colo79Ford's Avatar
Colo79Ford
Colo79Ford is offline
The 400 can be a good motor, you should go for it. Just my opinion.
---JOHN
Old 09-14-2004, 04:15 PM
XFracture's Avatar
XFracture
I sent you an email... it says you are not allowing PM's...
Old 11-17-2004, 02:43 PM
qman's Avatar
qman
qman is offline
Have you tried jetting down your carb? At this altitude you can use smaller jets and get the same performance. It might not be smoke blowing out your tailpipe but instead unburnt fuel. I had the same problem with two of my trucks. If your plugs are all black and sooty then you probably could use smaller jets.
Old 12-23-2004, 04:51 PM
truchafuego's Avatar
truchafuego
truchafuego is offline
Hey If you haven't bought another engine-I was thinking about buying this '65 4x4 F100 in Denver that has a 400 in it. I don't really want a 400 and would consider buying it and then selling the motor to you. I could use a 352 or 300 instead. I don't need a 400 double barrel carb stomp machine.
Old 12-23-2004, 07:58 PM
Colo79Ford's Avatar
Colo79Ford
What would you ask for the 400...I dont need one, but who knows..
--John
Old 12-24-2004, 10:12 AM
XFracture's Avatar
XFracture
I was going to by the one from the fella way up top, but ran into some financial burdens. How much would you want for it? And, does it run ? Smoke?
Old 12-31-2004, 01:38 PM
krazdndenver's Avatar
krazdndenver
krazdndenver is offline
5.0L EFI For Sale
Do you still need a V8? This is post here in the site in colorado. Please call me if you still need one.
Quick Reply: Need an engine...
