Whats the difference between light and heavy duty?
Sorry I haven't replied earlier. I was in the wrong screen and didn't see the other messages. I was told to look and see if it has dual piston calipers but I'm not sure if I can tell without removing the wheel. Ford dealer just told me that if it has the big axle hub coming through the rear wheel it's a heavy duty (1-ton) chassis, which my truck has. That may have answered my question. I'm leaving work now so I'll check back tomorrow to see if there are any additional ideas. Thanx for the help.
The 2wd had front discs in 74. The 4x4 didn't come with discs until 76. All the trucks had the hub sticking thru the rear wheel. As far as seeing the dual piston calipers, if you crawl to where you can see the back side of the wheel, then you can see if there is 2 bulges for 2 pistons on the calipers. That is if you have a 2wd. As far as 4x4 HD brakes, I don't know. Anyone else?
are you sure it's not 8400 GVW. or 8500GVW. mine is a 8400GVW and when they ask i always say heavy duty and it's the right part everytime. i have a 4500# front axle.
-Aaron
1978 F-250 Ranger Explorer Trailer Special 4x4
351M, C6, Np205, D44HD, D60 4.10LS
On the older trucks I suppose it's possible, I am only going by dealers say so and all of the trucks I was buying parts for were 83 and newer, up to 96. My owners manual also says this but it's an 89 so...? There are also sometimes HD parts used for the camper special and trailer special but then they give them the lower weight rating because the truck did not have to be certified as HD Emissions that way.
Mike
-Aaron
Mike
