ABS Relay Location
ABS Relay Location
Been looking in 3 different books and I can't determine the location of the "ABS Relay #1". Found "Relay #2" in the Engine Compartment Fuse Box but no references to where the other one is. It has to be in Haynes, Chiltons, or the Owners Manual but I can't find it. Is it on the bank of relays next to the Engine Compartment Fuse Box?
I'm trying to work through the ABS troubleshooting for Code 17. So far I know I don't have voltage on pin 17 of the ECU harness (in run).
Thanx
Chris
Thanx
Chris
Getting closer. Followed some wires and found the sucker. Now I'm getting stuck. I have no voltage on the Dk Gr side of the diode (in run). Also all O/Y wires (in run w/ diode in) are 0 Volts. I swapped relays around and no difference. I assume something is shorted to ground, that's why the ABS light is on, right? Getting lost in the detail, first time I'm delving into the electrical.
Also when I pull the fuse (17) for the ABS indicator I get a different chime sound, almost like a beep. Chimes five times then pauses and does it again.
mikebart
11-12-2019 06:46 PM
EricExplorer
11-03-2014 07:08 PM
