Gas Tank Vent
Old 09-01-2004, 03:16 PM
MILLHOUSEB's Avatar
MILLHOUSEB
MILLHOUSEB is offline
Gas Tank Vent
I just removed ALL the pollution control stuff on my '79 crew cab with a 351m. I got rid of the air pump, egr, cat converter, vacuum lines, etc. I replaced the intake with a performer & installed a street avenger 570cfm carb. It looks so much cleaner and the truck has never run better. My question is I need to know what to do with the vent line from the gas tank. It used to go to the charcoal box that I removed that was attached to the frame. Right now the line is just open in the engine compartment. What should I do with it? Is there any fire danger? Is gas evaporating? Any ideas would be great!
Thanks
Old 09-01-2004, 07:25 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Personally, I would reinstall the charcol canster and just hook the line to it. This will keep the fumes contained and reduce fuel evaporation.
Old 09-01-2004, 10:10 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
To install the cannister correctly there needs to be a line to the PCV valve that will draw air back thru the cannister to purge it. If you don't it will saturate with fuel vapor and drip just like the vent line will. Find the stuff you need and put the system back on.
Old 09-01-2004, 10:49 PM
whalerron's Avatar
whalerron
whalerron is offline
On my 1973 F100, there is a hose that goes from the charcoal canister to the air cleaner housing. That setup causes the fumes to be drawn into the carb and burned.
Old 09-02-2004, 12:50 AM
Torque1st's Avatar
Torque1st
Posting Legend
There are several types of cannisters, some use the hose to the air cleaner and others use hoses to the PCV or thru solenoid valves for more precise control.
Old 09-02-2004, 04:14 AM
79RangerJoel's Avatar
79RangerJoel
79RangerJoel is offline
I'm about to pull an old cylinder type of canister off of an older model F-150 and just connect the fuel vent to it, then run a hose to the air cleaner. That way I don't have to go through the 58 connections to 12 different places, and the engine compartment doesn't smell like gasoline all the time. Though, I guess this might be a bit difficult for you if you have a performance air cleaner on top of your new carburetor...
Old 09-02-2004, 08:44 AM
thebarnyard13's Avatar
thebarnyard13
thebarnyard13 is offline
Can I jump in here? I have done about the same thing. Went from 2B to 4B carb, replaced intake manifold and ditched the emmisions on my 1979 F250 and left the line to the box. I ran this way for about 1 1/2 years. I just ordered a new gas tank with out the vent so I could get rid of the line and box all together. Is that the wrong approach?
Old 09-02-2004, 08:59 AM
73Custom's Avatar
73Custom
73Custom is offline
That should work if you get a new gas cap. The unvented tank requires a vented gas cap.
Marty
Old 09-02-2004, 09:55 AM
Torque1st's Avatar
Torque1st
Posting Legend
If you can set your truck up with a vapor recovery system it is better in the long run.
Old 09-02-2004, 10:17 AM
ms_michelle's Avatar
ms_michelle
ms_michelle is offline
By all means put the canister back on and as it could prevent a fire, and does nothing to distract from performance.
Michelle
turnrjr
15
10-05-2011 01:01 PM
JSP2242
11-09-2010 06:40 PM
hdfx81
1966 - 1977 Early Broncos
05-22-2008 07:46 PM
a040599
17
06-16-2007 02:54 PM
yellow73bb
06-10-2004 09:29 AM
Quick Reply: Gas Tank Vent
