'88 Bronco-Tailgate Window wont go down
Do either one of your switches work ? If not, there's a real good chance that it has popped off of the inner latch on the key side of the tailgate. This happens to mine quiet often. What you do is push in very, very hard to the left of the key and turn the key at the same time to the right so it will hopefully come down. I am assuming that it has been going up and down before now ? Once you get it down, you can try adjusting the striker a littleeither up, down, in or out. I don't have mine adjusted properly so it will pop off every week or so and make a pretty load sound in the back of the Bronco. The 1st few times it popped off, I thought some kids were throwing stuff at me.
Search this forum and I quarantee that you will find tons of info on this exact subject.
Good luck,
Good luck,
mattbrock
11-23-2011 03:46 PM
GeoTracker
1978 - 1996 Big Bronco
13
05-31-2004 03:02 AM
